1 - 20 of 22 Posts
I just replaced my 26's with 28's and I am thinking I might be making a mistake.
Car is a single turbo 302 3550 race weight
530hp,500ftlbs
PA supercomp AODE
Thinking the load will be good for the turbo but not sure.
i was told with a turbo set up, you lowest nermical gear you can run to help spool the turbo, but i have no experince
You should be fine. 327's are what you want forsure and the 28 will give you plenty of traction. I run a 275 60 radial which is 28'' high and it is about perfect for a mid ten second runs
Rich I have 26X10 MT with 2 passes in the 1/8th if you dont like the 28s. I really like 28x9s just for the fact the tuct in so well. Maybe we can trade tires just let me know.
3.27's would be fine if you made about 1200hp
What??
Its a turbo car, Completly different than any other type of power adder. You need a low gear. 3.73 are only good for low elevens in a turbo car, which you could run 9.0's in a nitrous car. The turbo cars gears should be low.
Like I said before it will be perfect
What??
3.73's are only good for low elevens in a turbo car? :lol:
It is true that turbo's do well with a load on the engine. That said, a 3.27 and a 28" tire is going to be slow off the line, and you're only going to be in 3rd for a second. I mean, at 6000rpms in third, he would be running a solid 150mph. 28" tires are probably a good move. But I bet money you will pick up ET by switching to atleast a 3.73, if not a 4.10, and keeping the taller tires
I think I am gonna return them and try to get a 26, I am thinking the car is gonna be a huge pig with them.
Maybe. I love my 28" tires, but my car is geared for them. The extra traction Helps at the unprepped tracks around central Florida, like Orlando and Gainesville :)
we ran a set of 28's on a buddies twin turbo junk yard set up it made 550 ish to the ground it was a stick car mide you but he used to leave on the rev limiter (5500rpm) and it would bog put a set of 26's on it and it would blow the tires off, just from my personal experiance, if your gonna run a 28 inch tire go at least 355's (guessing not noing your set up of coarse!)
What??
:idunno:
I run 28s with 3.27s....they are great if you're going 170.
I;ll bet he has a stock rev limiter and is probably shifting anywere from 5500 to 5800 in his power curve. And it would also depend on his convertor slipage aswell.
Discussion Starter #16
Thanks for the links, the gears are already there but no one really mentioned tire size in those posts, and most of the guys had 5 speeds and I am running an auto
Yea, and a 5spd, with a 3.35 first gear is going to get out of the hole alot better than an AODE with a 2.40 first. Also, most of those threads are about daily drivers.
You know, thinking about it, my buddies turbo car runs pretty well with a 3.27 rear gear. Granted, he is running twin 88's, a big inch windsor, and a 'glide, not to mention 190mph out the back end, but what works for one, must work on them all, right?
Me personally I would run the 28's with the 3.27s
I have about 100 or so more hp but I just made the swap from 3.55s to a 3.31 and find out friday.
You have to remember a higher numerical gear ratio is used for mechanical advantage. Basically to help the car feel lighter. With a turbo that makes a lot of torque the higher numerical gear ratio is not as important. So in many situations people with turbo cars run a 28" tall tire and a 3.27 or 3.55 gear. Every car and combo is different. Testing is about the only way you will know for sure what will be best for you.
I run 275/50/15's with a 3.08 gear and the car likes it , granted im not at your power level.
on the same day on back to back passes i tried 28x11.5 et streets and went 11.20 at 120 , bolted on the 275/50 drag radials and went 10.88 at 124 .
1 - 20 of 22 Posts
