I planning on putting afr 165's,ported and polished GT40 u/l , 65mm t/b, BBK long tubes, x pipe, 4.10's, cam(un sure what to go with). How do I know what MAF and injectors to get. How will 73mm C&L with 30lb. injectors do? Thank you.
my buddy that got the 73 C&L loves it. im about to buy 24 lb fms injectors, 76C&L maf, and mac 70 mm TB. this is prepping for my Trick Flows that im going to be puttin on. just figured i'de share. i could also let you know how they feel if any difference when i get em.
Vinny
24's would be fine. With 30's you would be over injected. Run them at about 42 PSI vac off and adjust from there.
