Go buy some very soft steel wool. Apply your fav wax(I use maquires) with the steel wool, and just take it back off using a towel.
You will be amazed at the difference in the car with un spotted windows!
I wish you guys lived near here, They have a product sold locally around here called "Exactly Right" it's an acidic cleaner and takes off water spots on glass... It also takes off the haze that all older glass has on it I didn't know how stained up my back window was until we used that stuff on there.. it made my back window absolutely clear!!!.....you wouldn't believe how good this stuff works!!!!!
I want to pain the underside of my car. The underside of my car is in good shape, a couple of areas have some light surface rust. What paint would be good to use? Any thoughts on this paint? https://www.amazon.com/dp/B004IQDHZW/ref=twister_B07SJ9JBXM?_encoding=UTF8&psc=1
Hello all, I recently picked up a 1 owner 03 Mach 1 with 26k on it. Previous owner (older gentleman) must not have been very knowledgeable about paint care. He did however take excellent care of the car otherwise. It has a few scratches here and there. The body otherwise is in great shape. Swirl...
I’m looking to put a sunroof back in that was originally a sunroof. I’m going to cut the roof off a donor.
Questions are, what side of the pillar is the roof wiring harness on and where is the connector located? Where is the runoff tube in the pillar and how can I remove that before cutting the...
I can't believe that I'm even asking this question, but I am looking for a company that makes quality floor mats. I've recently switched the interior color, and I am looking to get a set of floor mats in Dark Charcoal Black. I've ordered a set from NPD, which was made by Auto Custom Carpets...
My window fell out of the track. So upon taking it apart I found the third mount in the door. So I bought the LMR brace kit and reinstalled everything. Have to put the window back in the tracks. What do I use? Is there a special silicone? It had some kind of foam in it before. Removed all I...
