1 - 8 of 8 Posts
I removed my ac and power steering but i cant get the stud out that they were mounted on that goes in the head.
put two nuts on the stud then jam the back (inner) one up against the front (outer) one. apply counter-clockwise force to the inner nut to remove the stud.
thats what i thought so i got to get another nut thanks
Just use some vise grips ;)
Nik
or use a dremel tool and put a slit in the end of the stud and screw it out
hear is a tip for stuck or rusted fasteners, even really bad exhaust bolts, use a hand torch and heat them (not glowing red hot) and they will back right out almost everytime and you wont damage them or the block, head or whatever it was in.
1 - 8 of 8 Posts
