Help!!.....I am in the middle of dropping my tank to put a new fuel pump in and I cant figure out how to disconnect the filler neck. Has anyone done this? Can anyone help me? My Hayes manual says I may have to cut some grommet. I don't know wtf they are talking about. There has to be an easier way.
PLEASE HELP ME!
it would be alot easier if you unbolt it where you put gas in, behind the gas cap lid. (if you haven't already) the one i dropped, we dropped because the grommet around the tank was shot, so i don't know if you have to cut that or not, but if you are going to drop it, it's probably not a bad idea to replace it anyhow. the grommet that they are talking about should be around the hole in the fuel tank where the filler neck goes into the tank. it just basically seals the filler neck so that no fuel leaks out of that hole. good luck with it ;)
