The calipers are the same.
The difference is rotor thickness & height, pads, and that the Cobra use a bracket that raises the caliper.
Eric
actually the calipers are slightly diff.
the fingers that come down and support the outside pade are a little bit longer.
but you can use them interchangebly. but I have GT's on mine and now have a set of cobras to put on with the cobra rotors when I get a chance it does make a dif as far as pad life.
the cobra rotors are thicker as well so the pads are the same but just shaved down versions.
