OK, I'm nearly done with converting my 1983 T-top GL to 1987+ interior. One of the last items to check off before I can throw down the carpet and seats is the installation of the 87 E-brake/parking brake. There are two differences from what I can discern that have to be taken care of to do this properly. #1 The two "buckets" that hold the E-brake assembly are not in the same location. The 83 is centered and the 87 offset a little over an inch. Initally I was just going to cut out the entire "hump of the trans tunnel there includign the seat belt mount, and weld the 87 in. That seems more work than necessary though. So do I just drill out the spot welds (PITA!!!) and just rivet or re-spot weld the 87 in with a little trimming to the opening to fit the 87 components? Anyone with experience on this?
#2 I've read that the adjustment for th eparkign brake is different between the 87 and 83. If I understand correctly, the 83 is tensioned underneath with a mechanism tied into the cable. In the 87, the adjustment is actually IN the handle itself. I'd like to NOT disable the tensioning mechanism in the brake handle. I'd liek the 87 piece to work as intended. What do I need to swap out to make this work correctly, or what do I need to change? If it makes any difference (shouldnt) the 83 already has an 8.8 in it and related brakes. (15 years ago). I cant remember changign any of the cables though.
