1 - 1 of 1 Posts
Well, the car runs fine with the new motor except for a HOt Start problem. If i let the car get all warmed up, or go to a gas station and shut it off for a couple mins, then try to fire it up....the engine will barely crank, as if the battery is almost dead, then all the sudden it will fire. I am not sure where the best spot to ground the battery to was, so I grouned it to the motor-mount bolt that goes into the block. Should I add an extra ground wire from here to the K-member, or should I ground it somewhere else, or is this even my problem?? josh
1 - 1 of 1 Posts
