after any repairs, I always clear the adaptives.I did use the 1263s3 (previously and now), but this time used RTV on the coolant ports. I notice the ford performance LMR kit comes with those extra water seals -mine did not.
RE Manifold: Saying I ported the manifold would be generous, I matched the head/gasket port per Chris' instructions in his video. I wasn't going for looks and think I achieved a 100 % functional effect.
Just fired it up after re-installing the manifold. I must say - running smoother. Still rich, condition unchanged in terms of O2 sensor output. Interesting accidental discovery just now - I left one coil unplugged, and that bank leaned out from 0.8 to 0.95. Plugged it back in - back to 0.8 on that bank.
Another interesting tid bit - when I change from closed loop fueling to open loop, it idles more smoothly - not sure how to quantify but it's very noticeable. Same thing happens when I modify the injector slope - I can get the O2 sensors to lambda = 1, but it idles rough. In open loop, it just runs like a top - the only thing is O2 sensors say it's rich.
I'm starting to get suspicious of the oxygen sensors.
I cleared them and have adaptives disabled for debugging.and unless the ports are so out of whack when it comes to alignment, port matching yields very little gain.
1) I win. Mike loses.I did use the 1263s3 (previously and now), but this time used RTV on the coolant ports. I notice the ford performance LMR kit comes with those extra water seals -mine did not.
Volts | kg/hr |
0 | 13.6242 |
0 | 13.6242 |
0 | 13.6242 |
0 | 13.6242 |
0.571045 | 13.6242 |
0.75 | 18.6936 |
0.884033 | 23.7631 |
1.09106 | 32.6346 |
1.18188 | 36.7535 |
1.32104 | 44.6745 |
1.46802 | 54.1798 |
1.57397 | 62.4176 |
1.69092 | 72.8734 |
1.80298 | 82.3786 |
1.88989 | 90.2996 |
1.98901 | 100.122 |
2.15405 | 120.083 |
2.31592 | 142.261 |
2.44995 | 161.272 |
2.58203 | 182.5 |
2.69409 | 201.828 |
2.90991 | 243.334 |
3.14893 | 295.612 |
3.35498 | 347.574 |
3.54395 | 399.219 |
3.88599 | 499.658 |
4.177 | 595.977 |
4.44312 | 695.465 |
4.76807 | 835.509 |
15.9998 | 835.509 |
this is a terrible idea.I'm going to verify if the MAF is correct by hooking up my stock MAF. Can anyone verify if this is the correct transfer function for a stock MAF, or know if they varied year to year? Found this one on another forum.
Volts kg/hr 0 13.6242 0 13.6242 0 13.6242 0 13.6242 0.571045 13.6242 0.75 18.6936 0.884033 23.7631 1.09106 32.6346 1.18188 36.7535 1.32104 44.6745 1.46802 54.1798 1.57397 62.4176 1.69092 72.8734 1.80298 82.3786 1.88989 90.2996 1.98901 100.122 2.15405 120.083 2.31592 142.261 2.44995 161.272 2.58203 182.5 2.69409 201.828 2.90991 243.334 3.14893 295.612 3.35498 347.574 3.54395 399.219 3.88599 499.658 4.177 595.977 4.44312 695.465 4.76807 835.509 15.9998 835.509
4 pin. Why is this a terrible idea? Systematically eliminating variables to root cause a problem I’ve been working on for over a month now.is there a 6 pin to 4 pin adapter at the maf connector?
The MAF I have on the car and was referring to in the previous post is the Pro M OTB MAF. The MAF I’ll put on the car to see if the OTB MAF is being silly is a stock ford MAF.is this a pro m 80?
gotcha.The MAF I have on the car and was referring to in the previous post is the Pro M OTB MAF. The MAF I’ll put on the car to see if the OTB MAF is being silly is a stock ford MAF.
Yes i'm thinking along similar lines - but how to verify? Order new O2 sensors?
- engine runs well when widebands say it’s rich
- engine runs poorly when widebands say it’s 14.7, and it gets there by removing lots of fuel from closed loop feedback.
Open loop runs well I assume based on the fact that open loop wouldn’t remove fuel?
I think you’re pursuing the wrong line of troubleshooting. All the above suggests a correct MAF and incorrect wideband reading.
Try another fresh air calibration in very fresh air. I wouldn’t even do it in a garage. I’d do it outside. If the sensors are in any type of exhaust fumes or propane heater fumes or anything like that, the calibration will be off.Yes i'm thinking along similar lines - but how to verify? Order new O2 sensors?
