Hi - found lots of good info on this forum from searching,vbut can't quite find this one:
89 lx, 363, COP, Pro-M intake and MAF/TB combo system. No crank trigger.
I've had struggle with the cam sync from day 1, been fighting this for about a month. Car starts, gets up to operating temperature, and will not always start again. First I replaced the distributor after reading the horror stories folks have with low quality aftermarket units. Since you can't get motorcraft, I bought a Performance Distributors forged unit for a 94-95, figured ditching the TFI module could only make things simpler/better. Chris said it would work. Wired it up - worked fine right away. I've now done two drives where the car won't restart after getting to operating temp. Looking at the data, when in this no-start condition, I am not getting EPOS_Sync_Level progressing past unsynchronized. So that would point to the distributor, but I find it so odd that it would work when cold and then not restart after being shut off. If the PIP sensor was failing when hot I would think the car would stop running randomly, but if it's running it stays running. When I pull the distributor out and spin it with a drill while watching the laptop, sometimes it does take a good 2-3 seconds to progress to Sync_720. I'd say 1 in 10 are slow. But it does always get to Sync_720
Other detail which I think is unrelated, so may be less relevant: I'm presently tuning base idle, fighting an off-idle drive ability issue. It stutters when coming right off idle, and dies when coming to a stop occasionally. I have 17" Hg of vacuum, and I removed all vacuum hoses and hooked up a gage at the throttle body and saw the same, so I don't think it's a vacuum leak. I haven't done a smoke test.
Help with either issue greatly appreciated!
