im gonna be doing the alt switch to the 130 amp alt, now i know to run a 8 guage wire from my starter relay to the + side now the only thing im not sure of even though i looked at a site is where is this white wire at that i tap into to go to my stator on the 130 alt? is the white wire that i tap into in the wires that go to the regulator or the other connector on top of the 75 amp alt, thanks for any help guy's ERIC
There are 2 plugs on the original 75 amp alternator. The one that goes into the voltage regulator will just plug into the voltage regulator on the 130 amp regulator. The other plug has two 10-gauge wires and a white wire in it. THAT IS THE WHITE WIRE YOU ARE LOOKING FOR..:joy: Just put a spade connector on it and plug it into the 130 amp alternators terminal for the stator.
Frank
bottlefed90gt
hey thank's alot for the info i need to do the switch,see i have a highpower stereo and amp and at an idle my volt's drop so i think the new alt should fix that. thank's ERIC
PS thank's buff hummer also!!!!!!!!!
