This is on my 94 Cobra. Ive got a MSD 6AL. Also have a Autometer 5 inch tach with shiftlite. I want to take the original shiftlite off and install the ninosport HUD shiftlite in. How would i do this.
Here is his website for the shiftlite. He doesnt tell you how to hook it up unless you have a rpm module. Any help would be apprecaited. Thanks
From the looks of the unit it appears that the reason an RPM Switch is needed is because the shift light has no "electronics" built in to determine when the light is activated. Since you already have a shift light tach, you should be able to just wire it into where your existing light plugs in on the tach. If nothing els, drop the guy an e-mail.
