What drill bit did you guys use to make the holes in the hood to install your hood pins or is there a special fiberglass drill bit for this....
Thanks......Darrin P/S 5006:)
I used a regular drill bit on mine....Drilled a pilot hole from the bottom of the hood up then went with the corresponding size drill bit from the top down...
Derek
I used a stepper type drill bit, you can drill a few diferent size holes with it. They sell it at Home Depot. I am pretty sure I eventually finished with a 3/4" hole to fit the locks through.
