Hey guys,
just wondering what you guys think of roller tip rockers as opposed to full roller rockers.
also i am running an x-303 cam (.544 lift i believe) will it be okay to run roller tip rockers with that cam on performer rpm heads?
the rockers are the comp cams magnum roller tip rockers.
I have heard good things about those rockers. I wouldnt want to use them on anything too radical like a solid roller with fairly high spring pressures. Comp recommends not using them with spring pressures exceeding 350lbs open. Having the ball fulrum will limit them in that respect.
