Banned
Has anyone experienced the actual headlight housing melt or become discolored from using higher wattage headlight bulbs?
I am aware of the issues with the socket, wiring, and/or light switches melting/burning from not using an upgraded harness.
I am only concerned with the headlight housing getting messed up. Has anyone had this happen?
I posted in the wrong thread. Sorry
Seeing first hand what a higher watt bulb can do with stock wiring here's my info.
A 80watt low 100watt high completely melted the plug into the headlight, the dimmer switch, headlight switch and started a small fire under the dash. 1500$ to repair at the dealer.
That said... (I know you mentioned you know but I just want to inform)
The short 2 weeks the bulbs were in the housings he didn't have any problems. I don't really think you will because the bulb really dosn't come close to anything in the fox light housings.
Banned
I believe if he had used an upgraded wiring harness or relays using thicker gauge wire, he wouldn't have had any issues with melting anything. I was under the same impression about the bulb in fox housing not coming real close to anything so I shouldn't have any issue....but I thought I would ask.
You must use a relay , thats why it melts the plugs. and A higher watt bulb throws off alot of heat, some more than others . Yes....Some will melt your housing. Why would you want these bulbs anyway , There annoying to other drivers , leave them for the big winged imports with fart cans.....
Banned
Have you seen this first hand? I am only concerned with mustang housings and if you have actually seen this problem.
