1 - 9 of 9 Posts
I have a new bug to figure out on my 91 GT. For the last couple weeks when I crank 'er up to 5500 the car falls off flat on its face and starts to backfire and sputter. I have new AFR 165's and the Holley Systemax upper and lower intake on a stock bottom end. Not boosted or NOS'd. Do I have a fuel delivery problem? I also installed an adjustable regulator and a 255 lph pump. Or possibly a broken valve spring? The car drives perfectly under 5500 but every time, right @ 5500 it falls off. I installed the intake and heads almost a year ago and this is the first problem.
distr and coil, also powers to them
Also could be weak valvesprings. This would not happen all of a sudden, and it would not happen until a higher RPM when the engine was cold.
Steve
Discussion Starter · #5 ·
I'm kinda leaning towards the valvesprings also. The car used to run flawlessly until the factory rev limiter until a week or so ago. I checked all of the plugs, and the cap and rotor are clean. There appears to be no excess play in the distributor either.
What cam are ya runnin??? If its stock why r ya tryin to take it to 5500??? And what is tellin ya that u r shiftin at 5500?? Anywho....do u have acess to a vacuum pump gauge??? If so here is to tell if the valvesprings are weak, or broken...with the pump hooked up the needle will fluctuate between 10"-21"Hg at idle rapidly. Of course, the fluctuations will increase with engine speed. And this will happen whenever the valve attempts to close.
Discussion Starter · #7 ·
I usually run it up towards 6000 because with the heads and intake the beast would pull right up 'til the limiter. I know I'm not the only one either! How do I know I'm shifting @ 5500? Good ol Auto Meter instrumentation. I do have a vacuum gauge onboard but it hasn't shown a difference the whole time. So am I looking at spark or fuel delivery issues now?
Discussion Starter · #9 ·
Fp is set at 41 psi, stock 19 lb/hr injectors (I know they're small but I do plan in upgrading once I get this bug worked out), stock rails, filter is about 6-8 months old. No ignition mods. I'm starting to wonder if there might be some deflection in the stock distributor or if one of the gears might be wearing?
1 - 9 of 9 Posts
