I've been trying to start my car but It just won't go.It barely cranks.When I pull the plugs it cranks a lot better.I've been having problems with my fuel pump staying on.I think it has flooded the car out but I don't know what the F is going on.Any suggestions would greatly be appreciated.
Sounds like a weak battery. Try charging it or swap it out with a good one to see. I think the computer requires at least 11 volts or it will start to do some strange things, this could be why your fuel pump is staying on.
THANKS BILLfor your reply.I actually had a car hooked up to it with jumper cables and a battery charger on it.It does make sense on what you say.I'll check into it.Any other suggestions would be appreciated.
