I'm looking to change my water pump to a "standard" clockwise direction pump (this will be for my 408w). I'm running across some conflicting information. Some people are saying just swap the WP with a standard direction pump and its done, others are saying it doesn't work with the timing cover? Then there is the pully, some say just run the ribbed side on a smooth pully and some say to change to a ribbed pulley.
My ultimate goal is a WP/CS/ALT setup only (see attached diagram)
If you have done this please chime in and let me know what parts you used.
Thanks for the help!
