Having trouble removing the center bolt up top.
ITs spining part of the strut??
Do I need a special tool?
Thanks,
Super Moderator
Yes, an impact wrench will zip it right off. Any local shop with a bay door open should be able to loosen them for you for a handshake. Or if you're going to be throwing the struts away, use vice grips on the shaft from inside the fenderwell to hold it still.
Moving to General Tech... Please keep Engine Tech, engine related.
SVT
