I need my car this Saturday for the Dyno and I got the egr spacer off and I broke a stud into my intake manifold, if I drill it out and tap it will it be okay to run Saturday for the dyno.There are two broken studs there. Apparently the one you broke on the bottom looks fresh, the one above it has been broken off for a while. This could have been a vacuum leak with only 3 studs holding the throttle body in place. I agree with Top heavy take the upper intake off. And even before trying to work on it take to a machine shop and have them hot tank the whole upper intake. Take all the hoses off and EGR valve off before hand.
I got the egr spacer off and the stud I broke is broke off in the intake manifold if I drill and tap it and put new studs and everything in will it be okay and also yes I am replacing the egr spacer with a 70mm with the 70mm throttle body and one last question I used screw drivers to try to pry the egr spacer off and I did actually cut a small slit at the bottom of my intake manifold with the new gasket will it be able to seal it off or should I be worriedGood point lol. Because it would be pointless to upgrade to a 70mm throttle body and not upgrade the EGR spacer to a 70mm.
okay so tmr I need to get some left hand drill bits and what do you mean by make the face flat and shouldn’t I only have to drill once and it’ll pull the stud out when I pull the drill bit outPut some silicone over the slit/scratch before new gasket goes on. Should be okay. Now the stud broken off in the intake is where you need to take strokeme advice on that.
Left hand drill bits. Make the face flat, perfectly centered punch, step up drill size as you go
The stud is actually loose in the manifold I was able to twist it when it snapped off so it might come out pretty easy but I have pics of the cut in the manifoldNope drilling it once will not pull it out. It is seized in there. Make the face of the broken off stud flat that way the drill bit doesn't walk off center. And after you make a punch directly in the center of the flat stud face, drill a pilot hole with a really small regular drill bit to start. Make that first hole perfectly centered and parallel/level with the upper intake. Luckily those studs are not a very hard material this is very doable. Take your time. Step up the hole with bigger regular drill bits till you get closer to the left hand drill bit sizes. And keep lubing it as you go.
Yeah I’m gonna try and drill it out today when I get off how should I make sure the rtv is flat in the scratchHard to make the face of the broken off stud flat when it's broken off inside the hole like it is. At least it's only one to deal with.
Hey so I got the throttle body on and I started the car and I can’t get it to idle right can anybody possibly FaceTime me or video chat me to help because I really need it to run tonight if I canThe scratch will be fine with a little rtv silicone over it before new gasket is put on. Let it dry for at least 6-12 hours
The car will run on the gas but won’t idle at allHey so I got the throttle body on and I started the car and I can’t get it to idle right can anybody possibly FaceTime me or video chat me to help because I really need it to run tonight if I can
I got everything on now the car won’t idle rightFissionable blasting materials now??
Okay I’m doing it nowYou need to do a base idle reset again.
It’s going through the base idle reset right now the idle keeps going up and back downYou need to do a base idle reset again.
The idle keeps dropping for just a second then it starts to idle high againIt’s going through the base idle reset right now the idle keeps going up and back down
