I need some help. I have some rear SVO lowering spring but don't have the front ones. I was thinking about cutting off the front stock springs to match the rear SVO ones. Is this bad, will it hurt anything and how much to I cut off. I'm only going to run these lowered spring untill I get the new K member on that I just bought so they'll only be on for about 3 months. Thanks for the help.
Get some 4 cylinder springs from the junk yard...I wouldn't cut the stock one's.
4cyl's lowered my car WAY too much.. it rubs and everything
I thought 4 cyl spring where the same height but just a little softer??? IF i cut my stock fronts, what would it do that is so bad. And has anyone ever done this? if so how much do I cut.
It doesn't hurt anything to cut a spring.
