Need info on porting Cobra upper/lower intake.
I need information on porting cobra/GT40/explorer intakes. I would like to see some pictures if anyone has any of what the ports should look like before and after porting.
[email protected]
:confused:
The best thing to do to the lower is match the ports to a Fel-Pro 1250 Intake Gasket. Put the gasket up to the intake and stensile (I hope that is spelled right) the size of the gasket to the port - most people use dye.
The upper is hard to pot unless you can re-weld it back together. One thing you can do though, is send it to Extrude Hone and they can smooth the upper for you.
-Rob-
:D
