Im trying to undo the water pump pulley bolts, but the thing just spins on me? its in fifth gear with the parking brake up wtf is going on
I wedged a small wrench between 2 of the bolts I wasn't loosening and put the other end of the wrench up against something solid on the engine...finally broke them loose...I guess just putting another wrench of the same size and having someone hold that one to keep the pulley from spinning while you turn the ratchet to loosen them would work too...
