1 - 1 of 1 Posts
Hello and thanks for taking the time to readmy post....
Now about timing, when I go to set it, I am prety sure its BTDC? correct? car is mostly stock, its a 92 AOD with 1 5/8 shorty headers, under drive pullies, MSD 6AL, MSD Coil, ford 9mm wires, BBK cold air intake, Flowmaster 2chamber. 65mm throttle body, 73mm Mass air.
Also with the Mass air, how do I clean this? do I just clean the thin wire that hangs in the center? do I clean it with a q-tip and alchol? (just wipe it clean?)
Thanks in advance!
1 - 1 of 1 Posts
