have a few questions and from other and older posts it seems like you know what you are talking about.
I have a 95 Saleen, I have dropped in a 408 Dart block, and running a Procharger D1. It is fuel injected, and intercooled. I have AFR205 heads, and trickflow valve covers on them.
That said. I have one large vacuum hole on the intake (Trick Flow R) upper, and have been told to hook it to the pvc. I have read a lot of people with and with out the PVC hooked up with superchargers. The valve covers do not have a filler neck or any holes.
I was planning on buying a kit like this for both sides: size -10an
http://www.jegs.com/i/JEGS+Performan...52230/10002/-1
1)And then running the -10an hose from each valve cover to a catch can with a vent filter on top. If this is correct, and you know a good catch can to use, let me know which one.
2) Is this correct, what is the best way to fill the oil or do I need a separate hole for an oil fill tube?
3) What to I do with the pvc, or hole in the intake?
4) Do you recommed a certain catch can, and is there an ideal place to drill the valce covers for the fittings I listed above?
Sorry for stupid questions, I am new to this stuff, I do body work, and electronics. I don't really under stand blow by, and other stuff I read in the forums. SO any help is greatly appreciated.
Thanks,
Brad
Thanks,
Brad
