Hey i bought a stock tape deck for my beater car, a 89 cavalier. I first installed it, and it worked ok, but it had a bracket on it that i needed to take off... I unplugged it, took the bracket off, plugged it back in and now the display wont light up, it wont switch between AM and FM, and all i get it a buzzing sound... When i wiggle the antenna cable it changes the buzzing sound, or kinda skips it. Also wheni turn the headlight switch on or some other devices it also changes the sound... Hop i described the problem clearly, any ideas on what it could be????
Just a thought, have you tried to put the bracket back on and see if this happens? If it does it might be a grounding issue or there is a short that "showed up" after you removed the bracket. Also what "bracket" was this and did you accidently bump the unit while removing it? Good Luck.
