1 - 13 of 13 Posts
Ok well I was in heavy traffic for and hour, moving almost no where in about 85-90 degree weather. All of a sudden smoke started to pour out from under my back seat, so i pull over and immediatly shut it down. Ironically the reason for the traffic was that another car completly went up in flames, and luckily there was a firetruck right next to me. They ripped up the back seat and took a fire estinglisher to the bottom foam of the seat.....a big chunk burned away but no real damage thank God. I'm guessing what happend is that my muffler got so hot it heated up the metal floor which got the seat hot enough to burn away. The reason why it got so hot is that im running with 3 cylinders which I think makes the car run hot, and on top of that I'm running rich so it was probably an inferno in the muffler. My question is, is there any fire proof insulation I can put inbetween the floor and the seat??? and where can I get some so I won't be burnt to a crisp next time... :mad: :confused:
Maybe the solution is to try not to run on 3 cylinders??
I seriously doubt this was caused by exhaust heat. I've NEVER seen that before. It almost would have had to of been electrical..
--Ed
yea i know the new engine is in the process.....I have a battery cable running back there but it wasnt close to where it caught on fire so that can't be the problem......i feel the floor under the seat after a short trip and its hot, so i can imagine how hot it got after 1hour traffic...
How about....don't drive it till ya get the new motor in? Your cats may have caused the problem, if they are still in there.
You got power seat????? Ford has the problem on power seat ciruit under the seat. Check it out will ya. It is under recall few years ago.
Discussion Starter · #6 ·
Yea I do have power seats, but where it burnt under the seat...there was no wiring. Think if I get like a fire blanket and put it inbetween the seat and the metal floor that would help, i mean they can't catch on fire? o well i still think its from exhaust heat...
Well, if you must, check out Mcmaster.com
They sell ceramic blanket. This stuff can insulate like you would not believe.
I used a 1" blanket to drop 300 degrees Farrenheight in an industrial application. THey sell 1/4, 1/2 etc...
very light stuff too.
PS cary a fire extinguisher....just in case.
just pull out the seat til the motor goes in.
arron
Discussion Starter · #9 ·
ok thanks for the info guys i think ill do a combo of taking the seat out and getting that blanket just in case.......I really need my B50 to be built fast..
smoking
Sure no one tossed a cigarette in your ride ? We have 90 + dg weather year round and ive never seen that happen.
Oh well good luck.
Discussion Starter · #11 ·
lol, im pretty sure about that......ive had my car for 2 years and have been in worse traffic and in warmer weather and that hasn't happend. It's probably the superchargers fault for making the car run much hotter along with the other things I mentioned.....I'm sure I won't have this problem with the new motor and tune, and if i do maybe a new radiator will help?
engine temperature is not really gonna effect exhaust heat, I mean the coolant temp, Exhaust temperature is super hot no matter what the temperature is outside and no matter how your car is running, they say the Cats get to 1600 deg when hot I have personally seen them set grass on fire on a lowered car, You exhaust pipe had to touch the bottom of the car you need to check that and stop being so defient to everyones advice, I dont believe and I think most people will agree with me it has nothing to do with how the car is running:)
Discussion Starter · #13 ·
Well first of all it wasnt my cats that caused the fire, if anything it was the mufflers cause they are right underneath there...you were probably just using the cats as an example though. the only reason why I think it was from running hot is because I have had the same exhaust setup for like 2 years so I dunno why it would all of a sudden cause this? So thats why I think its because of my car running hotter, the first time i get into traffic in hot weather this happens.....i dunno i guess it could be a coincidence. but ill have to check to see if any exhaust is touching.
1 - 13 of 13 Posts
