This my current combo i'm building.
Trick Flow Twisted Wedge
Ford Racing E303 Cam
Refreshed 302 5.0
Edelbrock Performer RPM
Holley 650 DP
Comp Cams 1.6 Roller Rockers
I wanted to know what cam would work best with this combo how much horsepower am i looking at ? And should i leave that same intake or upgrade to a victor jr. Thanks ahead of time for any help.
Well the cam would be in the 208ish range with a mild split in duration. You need to get a set of 8 1.7 rockers and put them on the intake lobes. Lift should be in the 500ish range on the intake and 470ish on exhaust. Keep the rpm intake, you'll never use the victors power range.
CStraub
