1990 mustang gt v1 vortech, heat has never worked and its been bad recently and I looked to fix the heat.. ac has been deleted. When trying the heat it will come on for say maybe 10 seconds, then it'll go off. Little while later it will come back on for say maybe 2 seconds and go back off and then repeat... while driving the rpm needle acts crazy like there's a loose wire when it turns on for those 2 seconds, Replaced the blower motor resistor and all 4 of the modes work now but it still does the same exact thing..
I've been suspecting maybe a loose ground and going to check when it gets a little warmer hopefully sooner than later but wanted to see if anyone had this problem or possibly a solution
