I'll say it before the others do....people are afraid of the nylon line...they have copper ones available that are less prone to melting when in contact with hot surfaces..
I have used the nylon line for a few years and had no problems so it is up to you.
Quick tip. Boil a pot of water and toss the line in it. The line will now be easy to handle and not tightly coiled.
Now onto the gauge..
No sender is needed. The fluid (HOT oil) running through the tube will be giving you your reading.
As to where to put it? Well I am not familiar with those vehicles so I cannot completely make out what I am viewing but it looks as if I see an idiot light sensor with possibly a plug next to it. If that is in fact for a low oil pressure indicator go ahead and remove that plug and first insert any adapter necessary, then your hose pieces. Make sure the ferrell is on the tube to ensure it seals.
