The fender is just bent in I need to pull it out and don't want to crack the paint or put a crease in it. What is the best way to go about doing this to get the fender line back up with the bumper cover? thanks
Grab it low and spread the load over the entire area, the wider the better. A block of wood as a backer and pull it ******d. Go slowly and watch for distortions. Naturally stop if you see anything getting too weird or overflexed.
If there are high spots flexing upward you should try to lower them with gentle pressure or even a tap from something firm, yet soft like a rubber block.
It's kinda hard to
