1 - 8 of 8 Posts
Can someone PLEASE!!! help me I am going nuts! I have an 86' Mustang SVO and the front ball joints are going out. I dont know enough about suspension to know what I am doing but I have had no luck at all locating this part i was told that The ball joints are set in to the lower control arm and that I would need to change them out completely. Can someone PLEASE! tell me what to do? Where I can get replacement parts. I really dont care to stay stock as I was told these are $600.00 each so can someone please tell me what to do to change this out? or were to get a kit to do so? I will go with a racing set if I need to jegs has this part (http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1439&prmenbr=361) but I did not know if this would work or not. THANK IN ADVANCE FOR THE INFO!!!
CONTROL ARMS
CHECK OUT THE SVO WEB SITES YOU CAN FIND USED ONES FOR 75 T 100 DOLLARS . SOMETIMES NEWS ONES FOR 175 EACH NO WAY IN **** I WOULD PAY 600 FOR THEM . HOPE THAT HELPS YOU .
I have tried that I am almost to the point of giving up. What I really need to know is, are there any after market kits that work or what would i need to do to make it work? I hate buying used parts cause most of the time i run in to the same problem. I was told that I could probably change it out with a set from the 5.0 is this true and what is involved in the switch. thanks for the reply though!
CAN YOU DO THAT FOR AN SVO???!!!??? Do you know the part number???!!!??? Please tell me what to do if you know how, I was under the impression that I could not find a Ball Joint that would fit, PLEASE!!!! tell me what the part number is and where to get it!!! THANKS!!!
D&D Motorsports just came out with a tubular control arm for the SVO. I don't know it the price is different from the others they sell but 79-02 A-Arms are priced arount $240.00 fot the pair
www.dndmotorsports.com
1 - 8 of 8 Posts
