I belive I posted it in the wrong place the 1st time, But Will 351W heads on my 87 5.0 give me more power then the stock head's??!!! It seems like it would get more flow
which 351W heads are you thinking about using? the only ones i would use are the C9OE's or the DOOE's. or '69 and '70. they flow significantly better than E7's and even have a smaller combustion chamber so you can boost your compression a bit. later model windsor heads have huge chambers and i wouldn't recommend putting them on your car.
