1 - 8 of 8 Posts
Bump
8548pt2
This is what I've been successfully using with both my AFR and Gt-40 heads with great success. The 1011's are junk.
The 8548PT2 is known as the FRPP "expanded graphite" gasket and it is a quality piece. But the 1011-1 and the 1011-2 are great as well. I've used all three with great results and I have been through Nitrous and many blower combos and all have held up well with ARP studs and a little copper spray... :) My last blower combo detonated so bad that it cracked the number 8 cylinder on a pass but the head gasket held up fine...
I have the 1011-1 on my 82 for 5 years. No probs. If you plan on using a poweradder another HG is in order.
Discussion Starter · #7 · (Edited)
Out of the 1011-1 or 1011-2 which one give you stock thickness for stock compression?
And is the 8548PT2 stock thickness as well?
Stock thickness I have no idea when you peel off the stock graphite headgasket and have to scrape the deck with a razor to clean it off. I am sure someone here can answer that. There are a few headgasket eaters here.
1 - 8 of 8 Posts
