1 - 8 of 8 Posts
I just bought one, and will be using it on a alum. manifold.. will those intake/carb studs. pull out the motor? and what did you use to secure the plate to the manifold? the same carb nuts?.. Thanks in advance.:)
I tried asking the same question, and didn't get too much of a response, so I just took off the headers, and bolted the chains to the head bolt/header bolt holes, lifted the engine and tranny out perfect.
Nothing beats the old fashioned chain
Yeah do it all the time. On Carbs you can use the same studs/nuts, just make sure they dont bottom out before hitting the plate (if so use washers to take up space).
Yeah, I did mine using a Summit lift plate and the bolts that hold down my upper Edelbrock manifold.
Worked like a charm.
Then used it on a buddies engine/ manual tranny combo. There I used 4 grade 8 bolts though.
Works great.
Formerly BLOWN1989SALEEN
i used one, but mine was an EFI application with 6 bolts as opposed to 4 with a carb application, i had good luck with mine this past winter. as said before be sure you get plenty of thread into the intake to avoid pulling the threads out.
Thanks guys for all of the input.. I will use that most likely today..... I appreciate the responses... Chrome.
1 - 8 of 8 Posts
