I have a 96GT that has been giving me problems starting in cold weather. It will turn over, fire up but will die unless I give it gas. It's fine after it warms up. Any suggestions?
Sounds like the world famous IAC valve.
Remove it and give it a clean with carb cleaner make sure the piston moves easily and put it back together. If that does not cure your problem then it is time to replace it.
You can also clean your MAF sensor while you are under the hood this can help also.
Dwayne
