· Registered
so another problem with the mustang
its running really really rich where it makes your eyes burn and the only way to start it is to give it alot of throttle after 5 seconds or cranking it also has a high idle.
the first startup its fine then if you turn it off and try to start it it will be real hard to start and smell like gas and white smoke/steam
i tryed adjustin the tps unpluging the maf and tps already
the fuel presure regulator does not leak out the vacuum hose
i have stock injectors and stock maf
· Registered
i ran the car with the mass air and tps sensor unplugged about a hour before the test, would that cause it to show up in a test a hour later
· Registered
Clear the codes and start over then repost the results, oh and clean the maf sensor elements but do so very carefully.
· Registered
54 ACT sensor signal is greater than the Self-Test maximum of 4.6 volts.
63 TPS circuit below minimum 0.6 volts.
TPS circuit has intermittently failed below minimum 0.6 volts.
66 MAF sensor went below 0.4 volts during the last 80 warm-up cycles.
TOT sensor output was less than Self-Test minimum value of 0.15 volts.
21 ECT out of self test range 0.3 to 3.7 volts.
44 Thermactor Air Injection system inoperative (Right side)
94 Thermactor Air Injection system inoperative (left side).
