I'm having some trouble with my stock 4.6. When I go to start it in the morning,it starts up and immediately stalls. Usually the second crank gets it going fine. The car idles fine.The next problem is that if you get into to loud pedal with any authority, it will stumble and sometimes backfire. Even after it is warmed up the car will not function when mashing the gas. It falls flat on it's face.The car acts like it's either getting too much gas or not enough. If you back out of the pedal it will start pulling around 1/2 throttle. I pulled some codes and they all have the same theme...EGR control not having adequate voltage. Too low. Has anyone had a problem like this. Help would be appreciated. I'll be cleaning the mass air meter tomorrow. One more question that might be related. If you put vacuum on the fuel pressure regulator,with a pump, should it hold vacuum? Thanks in advance..
i'd consider checking the DPFE hoses and/or replacing the DPFE.
check to make sure the EVR is plugged in.
Re: Re: Hard Cold Starts/Hesitation?'s
Ok. You just lost me with the DPFE. What's that?The EVR is the little black canister looking deal,just behind the TB, with the 2 vac hoses on the bottom.One going to the egr and has a 2 wire plug in it?Thanks
Re: Re: Re: Hard Cold Starts/Hesitation?'s
yeah. thats the EVR.
The DPFE sensor is the sensor that has two small hoses going to the EGR tube. it senses exhaust back pressure.
the DPFE is mounted near the firewall. its black (or silver) and is the size of a credit card and as thick as a casette tape.
mine did the same thing sometimes. I just ignored it and it went away.
Ahhh...you just described my car. It does this every so often. I thought it was the new location of the O2 sensors with my Longtube headers though. Hmmmm....Subscribing.
