They're both pretty much the same.
block off and tape over all of the bolt holes or else the mix will get in there....and you cant get it out...!!!
Buttttt if you're doing it to a 302 block in hopes to make it stronger it won't help since the weakest link is right down the middle where the filler won't affect it...Just FYI since I was interested in the same thing
half filling a late roller block does not do anything to strengthen the allready weakest part which is the lack of material in valley and the webing between the cam bearings to the main bearing saddles.....
