So heres the deal, I had a rough idle and sometimes the car just would not drop in RPMs after inbetween shifts or when i would push in the clutch right away. I have literally replaced everything in the ignition and fuel system on this car hunting down several problems (some not related here.) I mean there is nothing left for you to suggest in those two systems. I've cleaned the MAF several times with nothing but maf cleaner and i was very careful with everything. The engine is next to stock, the only difference is a CAI. There are no vacuum leaks anywhere on this motor and i've recently replaced the PCV valve and triple checked to make sure all lines are still hooked up. So, next step, replacing the IAC. It seemed to help out with the rough idle and rich smells i was getting before, but now the RPMS hover for a few seconds before dropping when i quickly throw in the clutch and it never drops between shifts. I'M OUT OF IDEAS. I've been hunting this too long.. please please help. (I've also done the surging idle/setting idle checklist, so thats been tried.. i'm not new to these cars by any means.)
