hey i just installed a hammer shifter on my mustang, and im runnig into some problems. i cant shift it into some gears.. and it gets really hard to shift..need some help!! thanks guys
i have a b&m shifter also and with mine you can adjust the length of the cable and you may have to over extended or to short.
thanks alot it works good now..but i am missing some of those clips to hold the boot and box thing down..do you know were i can get any?? thanks matt
I was missing two of those clips also. I called B& M, they sent me a small
bag of six. But,.. I didn't want to wait so, took one to Ace - Hardware and
got a couple clips that accept a bolt to go thru it. I used those (without a bolt)
and just bent them a little, little bit to make them work just like the stockers.
I just got done looking in the garage for the ones from B&M, ( woulda sent
a couple to ya), I can't find them right now. If I find them tonight, I'll PM ya.
I have one in my car as well, It had a non ajustable cable, and wouoldnt go into park at first. I ended up mounting the cable to the other side of the bracket, and shimming it it some. As for my boot, it has all the clips, but would still pull up, so i had to glue it down. Good luck with yours.
