I wonder how the shop does the solid spacer, do they set it up to spec with a crush sleeve and then change that out for a solid spacer? Must be a good shop!
You had mentioned sub 1:30s at PIR with the Volvo, have you been there with the Fox in it's current state?
Not sure I agree about the overdrive being prone to breakage, T5s for instance most often break third. Due to the ratio being so numerically low there isn't anywhere near the torque multiplication in overdrive as in the lower gears. I think it comes down to a case if you need the gear on track or not. If not needed then it would be a waste to bother.
Jay
They measured pinion rotational torque with the old setup first and measured the crush sleeve on the old setup and used that as a starting point, they know what they are doing, they only do gears and transmissions period.
I went back and looked, the fastest I have been in the Volvo was a 1.31. Have not beat that with the Fox yet. I am really close. Fastest lap around PIR has been in the M2....Bone ass stock M2.
Well, it will be a pictureless update for a number of reasons.
Picked up the car from the shop on Friday and loaded it straight on the trailer to head up to The Ridge in Shelton for Saturday and Sunday.
Got to the Track at 7 am on Saturday and the paddock had no room for truck and trailers so I was forced to park and unload in overflow parking and then drove the car over to pit with my buddies about a 10 minute walk from the truck......
It seemed like an ok plan until the 20th trip back and forth to the tow rig in 90 degree weather hauling all of my tools, fuel, drill, and all kinds of other ****. It was the nail in the coffin for me later in the day.
First session out on track went ok, getting the feel for the new gears and the hang of the track. First opinion of the gears is that I ****ed up. Second opinion of them is the same. For so many reasons. Car is a dog on corner exits now. Places that I used to be able to keep the car in 3rd and pull hard out of the corners, now I am stuck with lots more shifting and still the car doesnt pull as hard as it used to. To top that off the car still doesnt MPH at all down the straights. I was able to pick up 5 mph before the car starts to break up but it runs like poo on the top end....More on this in a bit.
The car handles amazing, crazy grip, the starter worked perfect all day, great oil pressure, never even got warm, it ran like 195 all day long in 90 degree sun all day. I was fast in the turns and so slow down the straights......Its really old at this point. My buddies were somewhere between 135 and 150 down the straight.
Sorry, back to the story. Ran the first session and got comfortable on track, came into pit after 15 minutes to find the back of the car covered in gear oil. They said that they overfilled the diff so I thought that probably was the cause. I got the car up on stands and drained out the extra fluid and cleaned things up.
Ran the second session and figuring out the car a bit, ran my fastest session at The Ridge ever and backed it up with 2 more laps. 1.58. This is about 5 seconds faster than last years fast lap in this ****pile so I am heading in the right direction.
Same issue, fluid all over so I got the car back up on jacks again, found some hose and built a ****ty little catch can for the vent line. So far from the truck I was working in the hot sun as I didnt have a way to get my pop up over to my buddies pit and nothing to tie it down to.
I ran the 3rd session of the day after lunch and had moved up in grid to the 5 of 15 spot in my run group so getting faster but the track was getting hot and going away, not to mention my head wasnt really in it so was only able to muster a 1.59 and not get any faster.
I was done at this point, frustrated with the car and the pit situation I packed it up and headed home.
I am not sure if I am looking for advice or not but Ill post up here and see what you guys say. Clearly its an ignition issue, but where do I even start. The new Tach I installed starts to go crazy at about 5k. When I say crazy it just bouces all over the place. This correlates to when the engine starts to run poorly and stop making any power. Is this a TFI Issue? Haltech Issue? Coil issue? Distributor issue? Pickup issue?
I am kind of done messing around with it at this point, its sorted enough that I could sell it to someone and they could have a riot with the car. For me to keep progressing with the car it needs to be faster but I am not sure I have the give a ****s to keep working on it.
Sorry for the lack of pics, makes one boring build thread =)
Sean
