1 - 8 of 8 Posts
Is there some trick to gutting this POS? I took the bolts out and "persuaded" the back partially out..It jsust won't come completely off and I don't want to force this damn thing and break it...Any ideas????? Anyone????
i need to know too, i wanna gut mine
Why do you want to gut it versus bypassing it?
i guess so i don't have to go thru the crap of rerouting the belt and getting a shorter one at that
maybe i'm just too lazy
Why, there is virtually no parasitic draw. I can see removing it to save the 15 lbs or whatever it weighs.
if nothing else, i guess just remove the pshhh pshhh pshhh noise it makes while pumping air. since i don't have the tube that connects down to the hpipe (off road) it dumps into the engine bay
Discussion Starter · #7 ·
Here's the deal...Remove the rear cover[It may take some force] and once the rear cover is out of the way using needle nose pliers or side cutters remove the phenolic vanes from the holders... You may need to get creative or medieval on its ass to do this....The vanes will come out in pieces then the vane holders will come out too...Lubricate the top roller bearing well and reinstall the rear cover....End of noise from the smog pump....
how difficult is it to measure the required belt length to bypass the smog pump (gain of about .0000005rwhp) and go to autozone, napa, etc. and buy a belt
1 - 8 of 8 Posts
