Can someone tell me the proper way to set up gt40p heads to work with a roller cam with a lift near .590. I know about the crane kit. Im wanting to do this w/o using the machine shop. Thanks in Advance
if you don't port it don't bother with that much lift, they don't flow more much past .500 on the intake side. I have an www.alexsparts.com kit in mine, not the beehive kit though, it wasn't available when I did mine. I run a comp cams XE270HR
Cool. Thanks...were yours simply gasket-masked or did you go a steps further?
I also used XE270HR-14 cam and a "drop-in" spring kit from AlexsParts with 40P heads. I also shaved the heads .030, machined to accept stud mount roller rockers and ported the exhaust side. It only ran 13.80 @ 100mph with AODE/3.27 geared rear but when I took it to the dyno we found some transmission slippage every time we hit full throttle.
The cam and spring kit did not require any machine work to use. I did the work looking to get more out of it.
I have an explorer upper/lower that I gasket matched a 70mm throttle body and the upper to lower. Didn't touch the lower to head even though it could have used a lot of work on both sides; 270rwhp/310tq.
I figured if I was going to go through all that I may as well get TWS heads first
