What all needs to be done?
Ive heard about the EGR valve, Ive also heard that its not necessary, but then youll need to reprogram your computer
If it doesent have the hole drilled and tapped in the #5 runner for the ACT sensor then that will have to be done or you can relocate it to the air inlet pipe before the throttle body. i have heard you can leave the sensor for the egr plugged in and just let it lay on the back of the motor there is also a product that plugs in and acts like the egr, ive seen it on this site but dont remember where.or you can just leave it off and itll throw CEL but i dont think there are any adverse affects from this other than a light bugging you. im not exactly sure of all of this cause i havent done it myself but i think thats how it works.
