Ok guys I have an 87 coupe with a 308 some kind of Aftermarket forged pistons. Edlebrock performer intake 52lbs injectors 340 pump an -8 feed line an-6 return ..and pro m efi system and pro m blow through 80mm mass air 75mm edle tb .gt 40 3 bar heads and a percision 7678 76mm turbo .a comp cam xe 274 cam .im trying to get the most out of this combo. I bought the car this way and trying to get it up and running .I have added some of these parts .like the pro m efi system my main question is what kind of power will I be making how much boost on the safe side .should I go ahead and get some better heads if so recommendations? Better cam like a blower cam or what cam would be best .Trans is a pa c4 full manual reverse valvebody 3600 stall converter ..plz help ..im sure I left out some info .any questions just ask
