Anyone else running Griggs rear coil overs with Baer rear wheel disc brakes?
I am having the problem that the brake bleeder is actually hitting the rear coil over spring.
I called Griggs and they said that I can either remove my emergency brake and mount the calipers on the front side of the rotors instead of the rear and that will give me enough room. OR I can take out the 2 bushings at the lower shock mount and cut new ones so that one side is longer and it moves it away from the bleeder.
Anyone else have this problem? How did you resolve it?
I have to put extended wheel studs in so the axles are comming out then I can move the caliper brakets.
What did you guys do, if anything?
