My 331 made 485hp 6800 rpms at the crank with some serious friction problems (spun Rod bearigs) . We made a few changes after we tore it back. We zero balanced the crank and put a super victor on it. We are expecting to see 550 [email protected]~7200 once the motor is tuned and dialed in. This will be going in a car that weighs 2900 lbs w/driver. I currently have 4.10 gears in the car and will be putting the power through a C-4 with a 5500-5800 stall. Should I try a 4.30 or 4.56 gear or will the 4.10's be right? The math I am doing with all the calculators says the car should run 134 mph (sound high to me) . But if its correct this would put me around 7300 rpms going through the traps.
Whats everyone think?
Whats everyone else using?
Rex
Rex
