The car seems solid, 122k, bone stock, runs well. The tranny whines, it seems a little more diffucult to get into each gear then normal. I am thinking this is the result of syncro issues? Also, at 60MPH the car has a bad vibration and pops out of 5th gear. I will check the tires tommorow, what other things should I look into? The vibration actually seems to be coming from the tranny, is that possible? Maybe the driveshaft?
I know I will have to rebuild the T5. Where can I get the rebuild kit? How much are they? Generally, will that kit have everything I will need?
Discussion Starter · #2 ·
