Ok, I ordered a set of APC clear corner lights for my 96 Cobra and did not accept them, Their quality was terrible, The rubber trim was held on by globs og glue and in most spots coming off. Any companies make a good quality peice?
For a factory fit you can make your own. Take out your lamps and take a very thin screwdriver and pry off the lens. Then remove the amber piece inside the lamp. Take some clear silicone and put a bead around the housing and put the lens back on. Let it dry and reinstall. You will have clear corners that will cost you just a few dollars for the clear silicone that maintain factory fit unlike so many of the aftermarket ones.
Thats what I am planning to do as well. Here is a thread on the subject:click!
